Cal's in vegas this week so I'm gonna post here while I try to get ahold of him and maybe someone here can figure this out.
The problem I'm having is there's no spark so I checked the MSD and Coil by removing the white distributor wire from the XFI and those checked out fine. Seems there is no signal from the crank sensor or from the distributor since the lights on the XFI arent lit up on anything besides power. I swapped the A3/A7 wires on the A-32p connector from the caspers 108112 adapter. Also have the dead end connector that is suppsoed to ground and supply 12v to both the cam and crank sensors.
Could this caspers105152 dead end connector be faulty?
This stock wire harness is in mint condition in a 35k original mile GN no other mods made to the harness and the stock motor ran pefectly fine on it. Just have no other Ideas on why this is happening, also checked the factory grounds that mount to rear of pass head they are all hooked up and fine. Swithced the crank sensor between 2 known good units.
When on my laptop looking at the XFI seen in the OPERATIONAL PARAMETERS the Buick DIS ignition system is selected,This correct? or should it be the IPU?
anyways any and all help would be greatly apperciated.
TIA
FGT
TIA
FGT
