My car's had a small oil leak since I bought it. It leaves a drop or two whenever it's parked. I always assumed it was the rear main, so I pulled the oil pan and was preparing to change the rear main seal when I noticed that there wasn't any oil on the back of the block. I ran a Q-tip around the cap joint and around the crank and it was bone dry so I left the cap alone and put the pan back on.
There's oil in the converter cover and the starter's covered. I assumed it must be the passenger side valve cover and oil was running around the starter and into the converter shield, but after changing the valve cover gasket I realized that wasn't it either.
Any ideas?
Thanks,
Mark
Any ideas?
Thanks,
Mark
