Where to put overflow w/ dual fans?
Toxic Donkey
I just replaced my ac compressor and lines in my gn. While everything was out of the way I finally popped in a 160* stat and gbody dual fans that Ive had since last year. I also have alky spray so I had the small overflow bottle mounted by stock fan. Now I just dont see a good place for it with the dual fan setup. For those with similar mods, where did u end up mounting the bottle. Thanks for any suggestions
Yep, in front of the battery is as good as any, a little hard to access at times but it isn't like you have to check it that often.
Same as 1952Ray, wasn't very $ on the auction site
1952ray... Idont even see the damn thing...
Oh my, in front of the turbo cover bolted to the top rad cover plate. The round alum. Cylinder. Maybe. 10" long going down in front of the pass fan. Has a small rad cap on top look at the top ,far left side of new picture. You will see the site tube of the coolant
