What Dennis said, plus the modules are hit or miss at best.
Has the TR6 changed in any way since Bob Bailey started making it? At the east coast Buick event in sept there was at least one case where a TR6 unit stopped working and reinstalling the stock module allowed the car to run. One other person locally has had two bad TR6 units.
The local person owns multiple TRs and the "bad" units were on two different seen, but I guess and tested on others. The car at the track was using LS coils and XIM along with the TR6. Maybe that had something to do with it. Odds of 3 cars having wiring issues vs odds of 3 non working TR6 units? Like mentioned above, maybe they are just overly sensitive to cam sensor position compared to a stock module and that is the issue. Not sure. My personal car went through two newer modules, one being bad out of the box. Currently using a NAPA Gold module that was new in box from 1992. At some point the TR6 may become our only option if the quality of replacement stock modules doesn't improve. Anyway, just sharing what I've seen, but compared to your experience I guess it's irrelevantWe have installed many TR6 units and they all are still working.
I have a GN here that I installed a fresh engine, and then it would not start with the TR6?
Removed the the TR6 and have tested it on 4 other cars, and worked on all of them. Installed his original coil pack/module and it runs fine.
So is there a possibility that your local persons have a wiring issue, and not a TR6 unit?
Of course you have verified that the 3 "bad" TR6 units have been tried on other GN's to verify that both were bad or defective or not set properly, and would not work on another turbo car before you posted this information?
I cannot tell you how many factory modules/coil packs are in my scrap pile as the are not working at all.
Partial information is bad information, especially on the internet where it can and does affect someone and/or their product. The least you could have posted information that these "bad" units would not work on other TR's.
Odds are that a TR6 will fail sometime like most all man-made parts, but what are the odds that 3 units are bad in your local area when this is the first time I have heard of any TR6 failure other than minor issues in the first field test units?
where is the best place to purchase a new ignition module and coil pack?
