I burn all my own chips for both my camaro and my talon, so I was wondering where one gets the stock or modifed bin files for TTA's?
Also would need the ecm, or xdf file for either tunercat or tunerpro or whatever you use to play with them.
Stock TTA and GN files on gnttype.org also http://www.gnttype.org/techarea/chips/chippage.html
AS for an editor, I use Tunercat because you can use the mod tool and define other tables for address space that is not already defined in the DEF file for the ECM you are using. Had to do this on the AE tables because they were not defined in the DEF file Tunercat provided for the GN.
