S SEP455 Turbo Steve Joined Oct 12, 2009 Oct 23, 2009 #1 Whats the biggest drag radial I can fit on an '86 Regal with 15x7 T-type rims without running a spacer?
H HOT ROD-GN Active Member Joined Jun 10, 2009 Oct 23, 2009 #2 SEP455 said: Whats the biggest drag radial I can fit on an '86 Regal with 15x7 T-type rims without running a spacer? Click to expand... 275
S SEP455 Turbo Steve Joined Oct 12, 2009 Oct 24, 2009 #3 I'm currently running a 255 drag radial, would changing to a 275 give me any advantage in the 1/4?
H HOT ROD-GN Active Member Joined Jun 10, 2009 Oct 24, 2009 #4 SEP455 said: I'm currently running a 255 drag radial, would changing to a 275 give me any advantage in the 1/4? Click to expand... depend on your combo?
T TurboJoe5.3 TURBO JOE Joined Oct 25, 2009 Oct 25, 2009 #5 naturally more tire = better traction. start experimenting with the tire Pressure and find your sweet spot and depending on temperature you should see a diff. I have a Ws6 that i went from 315s to 335s and the difference was amazing
