N N2HIPSI 1 of 463 Joined Feb 10, 2002 May 13, 2002 #1 If a car has a good breathing combo, how much horsepower is a pound of boost worth? For example: see my signature.
N NEARING Active Member Joined Apr 9, 2002 May 13, 2002 #2 I would like to know too. I've heard 12-15 hp?
T TT/Ameasap The White Blur Joined Jan 31, 2002 May 13, 2002 #3 Thats what i hear... 12hp-15hp depending on combo
T Turbo__Tim One heck of a Tim! Joined May 25, 2001 May 13, 2002 #4 Reading of the different dyno tests over the years seems to indicate that 12 HP per pound is about right.
T ThikStik My sleep apnea is winning Joined Mar 27, 2002 May 15, 2002 #5 7% power increase per psi, but im a junior member what can i possibly know.
K kenny No turbo, no care. Joined Apr 13, 2002 May 15, 2002 #6 http://www.forcefed.cc/forums/showthread.php?s=&threadid=3
B BlackBeauty Member Joined Dec 15, 2001 May 15, 2002 #7 I believe 1 psi=8-12hp approx., when I estimate power gain, I use 8hp per pound of boost just to be conservative.
I idaho gn behind the learning curve Joined May 25, 2001 May 15, 2002 #8 i dont know on a rear wheel dyno run increasiing from 21 to 23 psi i made 36 more hp to the rear wheels the dyno weather station was at 5300 ft during this run shawn
G G McCall Member Joined May 30, 2001 May 15, 2002 #9 SO many variables. My experience says 15-18 hp per 1Lb boost with a 12.00 and faster car. 8-12 is for a more stock setup.
B blackbuick87 Senior Member Joined Mar 11, 2002 May 15, 2002 #10 A car with a big IC, cam and better flowing heads will definitely make better power per pound.
