I know the obvious answer is improper voltage, but I'm looking for some specifics. A few days ago my voltage light came on dimly and it hasn't gone away. I say dimly because it's barely visible in daylight, and when the key is on, engine off (and the voltage light is lit as it should be) it is MUCH brighter. The alternator is only a few months and a few thousand miles old, and the belt doesn;t seem to be slipping. My Scanmaster reads anywhere from 12.5-13.5 volts, which seems about right to me. I haven't gotten quality readings from a multimeter yet to verify the scanmaster, though I guess that would be next.
My main question is what parameters will trigger a volt light, is it just a lower bound (anytime voltage dips below 'x') or an upper and lower bound (anytime voltage is less than 'x' or greater than 'y')? If so, does anyone know what the upper and/or lower bounds are? Also, Since my actual voltage seems to be normal, and the light is lit only dimly, are there other things that could erroneously trigger the 'volts' light? I have noticed for a while now that the readout for fuel remaining (i have the digital dash) will occasionally blink to "--" for an instant so maybe theres something goofy going on in the dash wiring? (though the fuel level thing has been going on for a while, whereas the volts light is new).
Any light you guys can shed would be helpful... its not a major problem, but it certainly is annoying. Oh, and my car is a hot-air if that makes any difference wiring-wise. Thanks!!
