what times?
jerrad
i was wonderig what i should expect with 24#s and slicks?
60' -2.049
330 -5.664
1/8 -8.772
mph-78.58
1000 -11.486
1/4 -13.809
mph -96.49
my car spun a little and had a little wheel hop and i was also at 20#s of boost the temp was about 80 degrees i also launched at about 4#s i couldnt hold any more boost
thanks jerrad
The mph and times seem to go together ok. Does seem low for the boost you are running though. Maybe at 17lbs boost or so you would get those numbers. For 20lbs boost looks like you are down on power for some reason.
Are you running the alchy chip from Turbotweak along with alchy injection? Might be some more tuning you need to do to get everything right.
Any knock? What was the O2 readings? What fuel pressure are you running at? What are the water temps reading? etc..... Just a couple of things to look at.
Post more info and I'm sure people will chime in with some suggestions.
Jerrad, times look ok for the 60 ft you got (a 1.80 would put you at a 13.4 or so) but your mph looks low, it isn't bad in the 1/8 mile but you should gain 21-22 mph on the topend from the 1/8 and that would put you at 100 or so. Have you changed your valve springs at all? And what were the knock readings if there were any? You should be able to run bottom 13s to high 12s at 102-105 with that setup on 24 psi with a 2.00 60 ft but with a 1.80 or better you could tune it down to a mid 12 possibly
i have stock valve springs put this winter im putting in lt1 springs. i have no knock. also what do you think my 0-60 mph would be on that run? also i had a little wheel spin so i think my 60 foot time would be 1.8 or 1.9 thanks for the help
jerrad
