counterman
- Dec 28, 2006
I just had a local shop rebuild the BRF 200 4r in my 87, and I cannot seem to get this thing to work right. I am aggravated because I tossed in lots of goodies from CK and PTS, amongst others, and it is behaving poorly. It is an original 56k mile unit that was flairing on the shifts pre rebuild. The unit holds 1st gear to about 4k at light throttle, and shifts when I lift slightly at that rpm. The shift is strong with no slip, but is late, and goes 2-3 immediately. It will not pick up od, and will downshift back to 2nd early on when the throttle is lifted. The car will stay in 2nd as you slow to a stop, and chugs as a result. I get first when I pull it back manually to low 1, and the trans idles and drives out ok in first. I am aggravated because I do not want to waste the parts I already have in the unit, but I feel a pro rebuild coming on. I should have done this one myself, and I would have been no worse for my efforts at this point. So, what are your thoughts? TV settings don't bother it much. Are we thinking valve body, or hard parts issue with a sprinkling of improper assembly? Thanks, Counterman.
