What Methanol is most commonly used
AntMan
Just interested in seeing what brand is most commonly used by board members!
Running the Razor's Dual Nozzel meth/alcohol kit.....
Thanks in advance!
Meth is meth as long as it has no upper cylinder lube or petroleum products.
Alot people run alot different meth products, the kit calls for 100 percent pure meth so thats what i put in mine. Need to be sure it is not contaminated in any way, such as using same pump for different product,ect. I also have a dedicated can and funnel used only to fill the tank. I also get mine at the same speed shop whenever i need more.
Straight VP M1 is the best out there, it's the most pure form available. If I remember correctly it's 99.9% pure. I would only use it from a direct source, as other chemicals will contaminate it. I buy 5 gallon cans from a local speed shop, this takes away any worry about contaminants.
