HelloBozos said:Thats one pissed off cricket...What rockers are on this? Might of lost a plastic push in rocker spacer if stock.Sure sound's valvetrain from video,maybe a collapsed lifter?
Good luck
turbo nasty said:Sounds like the ignition (pack/mod) is grounding out somehow.
Also check the vac lines and check valves around there.
I have put a screw driver to my ear and checked all mechanical areas while trying to hear this noise and nothing. Stock top end to my knowledge.
TurboBuRick said:Did you put your hand on top of the coil pack? Don't really do that.
It sounds like spark is jumping to ground. Like a bad spark plug wire or a cracked boot. Like mentioned you might find it more easy in the dark.
RL
pmoore4321 said:No doubt that is arcing
groumoutis said:Which side does it sound like its coming from? I think it sounds like the spring in the pcv is gone and the pcv is rattling back and forth. Then again I am listening to it on my iPhone and not on a nice sound system. Just guessing because it does sound metallic on my phone and it is the right area.
NorEaster said:Wow good idea. Its coming from that side of the engine. Also I installed an RJC pcv but didn't like how my car ran with it so I put it inline with my stock pcv.
I did not do the screw driver test on the pcv. Ill check that tonight.
