I agree with Turbo Nasty that you need ZDDP in your oil which the majority of current oils do not offer. If you search on "oil" and "ZDDP" you will see many threads on this matter.
I personally run Joe Gibbs "Hot Rod" oil, 10w30. It has all the good old stuff in the oil our flat tappet cams need. Not the cheapest though - it lists for 10.99 a quart but if you search around online you can find it for about $7.95 a quart. There are cheaper options than this, but the Joe Gibbs Hot Rod Oil is peace of mind for me and my 50,000 mile original motor.
I am sure many others will jump in and discuss STP additive with ZDDP in it as well as the ZDDP additive Kirban sells. I believe all are good options (another good option is diesel engine oils) to give our flat tappet cams the protection they require.
