Like I said in my earlier post, go to napa and order a NEW master cyl/vac booster
ASSEMBLY for a 1987 V8 Regal. The booster comes with the pushrod, and you simply remove the powermaster and adapter during the install, and the new assembly bolts right up. The only other thing you'll need is the pedal - from any mid 80's G-Body with vac. brakes (regal, monte, cutlass, grand prix), and about 4 feet of 3/8 vac. hose, and a 3/8" plastic 'T'. If you want, I'll take a pic of how my vac is plumbed, and you can give it to the installer to duplicate. Excellent instructions for the swap that you can print out and give to the installer are on gnttype.org... hell, here's the link...
Powermaster To Vacuum Brake Conversion
Vacuum Brake Swap
It's super easy and straight forward. Hardest thing is changing the pedal (1 bolt and 1 pin), and that is only annoying because of the inconvenient location of the parts.
