The relationship between the machining of the timing sprocket holes and lobes will be different from cam to cam, so yeah, it is best to degree a cam. I think its comp cams or crane that usually grinds all their cams 4 degrees advanced. When the chain stretches over time, then the cam will end up roughly straight up. If you dont have the means to degree it with offset keys and all the tooling, you will usually get decent luck just throwing it in straight up. Ive seen major losses in power advancing or retarding 4 degrees, even when done with proper tools. The rocker arm assembly is a total joke on these engines. The stamped steel holes for the shafts are usually really worn out and you use alot of lift. If I ever were to change cams, I wouldnt think twice about going with roller rockers and maybe even a roller cam. if money werent an object, Its the obvious choice.
