been chasing a knock problem a lower boost around 6-10 i get 10 or below degrees of knock. went for a drive to run the #'s and my recall said i had 590's o2 and 6.3 degrees of knock! usually my 02's are mid 7's to lower 8's with the same amount of KR is there anything i can go and check or re adjust or anything my new chip has not arrived but i want to be better in tune when it gets here.
here is how the car is set up now and tell me if something is off
43 line off
cr43ts gaped at 35
boost is set at 15lbs
tps is .44
the only #'s i see off the charts is block learn is 105 and specs are 118-135
and lv8 is 48 and specs are 30-40
all #'s are at idle
43 line off
cr43ts gaped at 35
tps is .44
all #'s are at idle
