I drilled the stat w/ some small holes, cut the nipple off the pump, tapped it for a pipe plug.
I used the manifold port for the aftermkt gauge sender. Cleans up the area around the cam sensor.
This mod does not affect the heater.Who needs heat and saves weight.
Where do you guys come up with these ideas?? LOL
got a picI drilled the stat w/ some small holes, cut the nipple off the pump, tapped it for a pipe plug.
A lot of times those icons get "hit" while scrolling on a phone and you don't even know you posted on someones comment . I did it by accident once myself , but took it back .I guess I will make another "dumb" post. Here it is, with part number.
http://www.turbobuick.com/forums/threads/oreilys-has-the-proper-s-bypass-hose.206252/
