I bought a new high pressure actuator from kirban, the one that came with my turbo from PT gave out. It works fine, but the placement of the actuator isnt the same as how it was from PT...PT welded a bracket to theirs to make an extra hole while kirbans just has the set holes, i guess for the stock turbo. Now my wastegate sits about an inch forward than before, the rod therefore is tilted further back and is not perfectly straight. Is this a problem? It seems to work fine now, but there is alot of pressure on the rod. Just wanted to know if I should customize this wastegate just like PT did.
