N Notplayn Member Joined Mar 22, 2003 May 6, 2012 #1 I want to repaint not only the tail light trim pieces but also the wheel opening mouldings, the trim on the trunk edge, key cylinders, ETC..... What is the correct color? Flat black, semi gloss??? Thanks..
J JC Turbo Well-Known Member Joined Jun 15, 2001 May 6, 2012 #2 If your looking for rattle can paint Dupli-color TP-70 trim paint is what you want. PepBoys carries it. Sent from my Droid using Turbo Buick
T turbo39151 anycoloraslongasitsblack Joined Nov 7, 2002 May 7, 2012 #4 SEM trim black or satin black.
O onefastgn Active Member Joined Nov 13, 2003 May 14, 2012 #5 turbo nasty said: SEM trim black Click to expand... X2 best stuff to use bar none!
