I don't want to slam the person who did the work on my intake. I'd like to figure out my next step though.
I had the stock iron TTA heads ported and installed by my engine builder. I later had my intake "port matched" and was persuaded to have it fully ported, the EGR welded and installed.
Last week I pulled off the upper plenum to look inside to inspect the work. I was supprised to see that the intake was not ported to exactly match the heads. A few of the ports matched, probably 5 or 6 had a lip on one side. The intake is ported larger on those ports than the heads.
I can't really just make the intake ports smaller to flow smoothly into the heads. The only thing I can think of is removing the heads and making the intake ports on the head larger to flow smoothly from the intake.
Here are my questions:
1. Is there any reason my engine guy would have done this on purpose. Could a lip (the thickness of a dime) some how improve performance? (I think I already know the answer)
2. Since the engine has never been run are my Cometic head gaskets reuseable?
This is my 4.1L stroker with hopes of high tens some day. Just spent quite a bit of money on new long block and want to do it right.
Thanks,
Eric
Thanks,
Eric
