Originally posted by sailor77
What do I do? 85 Riv, all stock. Looks like I will be going to an 84/85 turbo regal turbo placement. What do I need to look for to get 250HP? Also will newer 3.8 FWD heads fit? I heard somewhere that they will and they flow better then the GN's.
I was thinking some head and intake work and a cam. What will that get me?
Hope I can help here, after reading some of you posts, and we have passed a few messages, this would be my best recomendation.
You should pull the motor/trans/wire harness out of the car keeping everything well labeled and organized.
Sell all the Riviera stuff you don't need so you can buy all the 84-5 turbo Regal stuff you need (headers , crossover, turbo, brackets,etc.)
Get motor cleaned up and install it in the Jeep. Most important thing for your success would be to install all the turbo Regal parts to your motor in completely stock 84-5 configuration FIRST, you will have your hands full just doing the hybrid swap. Remember you have to get your trans to work with the motor, oil pan clearance, motor mounts, radiator hook up, electrical hook ups, etc, it is going to be a challenge enough, get it running stock first, now you will have a baseline to make performance upgrades.
Nothing wrong with asking how to make more power, but you do have some work ahead just to get it running stock, but at least it wil be easier to get help to make it run stock if you do run into initial problems (mixed up wires, turbo plumbing leaks, fitment, etc.)
Now go pull the motor and sell us what you don't need (cash waiting) , get the hotair Regal parts you need , and have fun with installing to Jeep. Do check again to make sure you will be able to use your trans or at least one that will work (can't help you there) with the buick engine. Oh, I'll have to help you identify the Riv differential, again a 3.36 ratio ( probably not though) i would buy from you, talk later.
