NationalGN
- May 20, 2009
hello all, can someone help explain how to get a fuel sock for walbro 340 if needed stock?, exsplain the 2electrical clips at tank were go thanks
If its a flat clip type connector outside the tank and you have a hotwire kit on the car, it slides on to the seam of the tank. If its a round connector with a hole in it, run it to a bolt. Its a supplemental ground wire.[/QUOTE
it has 2 conectors one with 3 , other square with 4 holes conector?
thanks for the help
Might try posting a picture of it.
DO you have a GSS340 or a GSS340M with a little M scratched in after the part number on the pump? They take a different sock
Mike
hello mike i have a gss340. i also slammed a cement brick into my shin and had a crowbar hit me in the mouuuth working on GN ooocchhh im still feeling it.
Mike
