Ah....I see. Well, it was suggested in an earlier post I left a few months back that the chain may have jumped. It's a 92k mi car, so I guess it's possible. Need a double roller in there anyway
No odd sounds as far as I remember...maybe I should just change the timing chain anyway. Do that, the fuel system(well, at least the regulator(got a 237 to go on), inj's, fuel pump, sock, clean the tank out while I'm at it....already replaced the filter about a month before it decided to quit running), valve springs, and a few sensors as needed. Just kinda freshen things up before the turbo goes back on... I'll check for spark and then if it's getting good spark...I guess I have to decide whether or not to start replacing stuff or just put it back and try again. At this point, it's easier to just replace a bunch of stuff and maybe fix the problem. I do have an 85engine on the stand though....it's got a double rolled filet crank, two-dot rods, new pistons, rebuilt heads, new cam, etc etc etc....basically everything but the block, heads, turbo, and intake were replaced and all those were redone to either improve them(heads and turbo rebuilt, rotating assembly balanced) or just make em look nice. I was hlding out for when this one quit, but I'd like to keep the original engine in it. I'd hate to drop in the other engine to find that something wasn't right in it and I only needed a timing chain or something little like that for the original... I got it when I got my 85T-Type I'm parting. The car is rusty, but the engine....well, he went a wee bit overboard for a hotair engine. He put over 2k in it and it's beautiful. Painted up black with polished: valve covers, accessory bracket, alternator, compressor housing on turbo(I did sell the turbo though....kinda regret it, but I needed cash and he needed a good turbo), and throttle body. Looks great, but I have no idea what the clearances are at and I'm hesitant to put it in and fire it up without first going in and at least plasti-gauging the rods and mains. Anyway, I'll try checking for spark and let you know how that goes. THANKYOU for your help!!!!!
