Ok all done with the engine work, put in new injectors, 87 waste gate actuator, and reworked everything I thought was even remotely questionable. Looks great and hold 10psi on the fuel rail after almost 2 days, ready to crank it up.....what I found is when the fans kick on idle drops off significantly, I would concider that normal, the duals have a serious current draw...but..fuel pressure drops as well, now that should not happen...should it????? I mean I can imagine that causing my WOT issues after the car warms up...If the fuel pressure drops because the fans are on then the engine will starve at WOT, I mean am I thinking correctly?????
