Up for sale are my VERY rare Kenne Bell headers, a PT71-GTQ turbo, and TiAl V44 44mm external wastegate. This is a complete kit to convert to a T4 4-bolt turbo setup with all fabrication work done and custom fit to our Buicks. The turbo sits in the stock location allowing you to use any existing intercooler and intake/cold air kit.
The 3 bolt flange that came on the headers was cut off and replaced with a 4 bolt flange, and a pipe welded to use the TiAL v44 wastegate. I still have the 3 bolt flange that will be shipped with the headers in case you want to run TSM or use your existing 3-bolt turbo. The headers also have an EGT bung beneath the wastegate pipe (see pic 1 or 4).
The turbo has a 4" inlet and 3" outlet. It did not smoke when removed but has a slight axial shaft play. I cant recall if it was like this when I put it on but wanted to mention this. There is almost zero radial play (wheels do NOT hit either inner housing opening even with pressure applied).
The TiAL wastegate is currently on ebay but I will end the auction early if someone wants on here wants it. TiAL 44mm 44 mm V44 polished wastegate and extra spring:eBay Motors (item 280388795663 end time Sep-02-09 18:11:13 PDT)
I also have the 90 degree 3.5" downpipe elbow as seen in the last pic that I am willing to throw in for free if someone wants to buy all three parts. It already has the vband flange to mount to the turbo and a WBO2 bung.
Headers: $400
Turbo: $650 ($1200 new)
Wastegate: $225 ($375 new)
or all for $975 SHIPPED!
Headers: $400
