W we4Mateo Double you eee what? Joined Apr 7, 2010 Dec 7, 2014 #1 Check out the valve spring rotation. Would like to see a Buick head under boost and rpm.
Boostian Member Joined Jul 8, 2013 Dec 8, 2014 #3 That's wild. Pretty cool to see them rotate like that. 1987 White Turbo T - TE60 w/ Alky 12.1@113 on street tires
2 20psiofevil Active Member Joined Feb 10, 2013 Dec 8, 2014 #4 Seen a similar video on fb a while back. Really shows the weak point in push rod motors.
Boostian Member Joined Jul 8, 2013 Dec 8, 2014 #5 20psiofevil said: Seen a similar video on fb a while back. Really shows the weak point in push rod motors. Click to expand... How is it weak? A spring is going to compress with the same force no matter how you spin it... 1987 White Turbo T - TE60 w/ Alky 12.1@113 on street tires
2 20psiofevil Active Member Joined Feb 10, 2013 Dec 9, 2014 #6 Boostian said: How is it weak? A spring is going to compress with the same force no matter how you spin it... 1987 White Turbo T - TE60 w/ Alky 12.1@113 on street tires Click to expand... Pushrod looks weaker to me due to it's geometry compared to what is in the video. I don't know of any push rod motor that turns 14,000 rpm.
W we4Mateo Double you eee what? Joined Apr 7, 2010 Dec 9, 2014 #7 20psiofevil said: Pushrod looks weaker to me due to it's geometry compared to what is in the video. I don't know of any push rod motor that turns 14,000 rpm. Click to expand... One has a rod between the cam and valve, the other actuates the valves directly. Apples and oranges. Pushrods have their place, for one packaging is amazing and gm seems to be able to make power as does Chrysler and both are fairly reliable.
G greeneyegi Well-Known Member Joined Feb 21, 2010 Dec 9, 2014 #8 Is that 14krpm the camshaft revolutions or the actual motor/crankshaft rpm? Watching it on my little phone screen
W we4Mateo Double you eee what? Joined Apr 7, 2010 Dec 10, 2014 #9 greeneyegi said: Is that 14krpm the camshaft revolutions or the actual motor/crankshaft rpm? Watching it on my little phone screen Click to expand... Pretty sure it's engine rpm so camshaft speed would be half.
Boostian Member Joined Jul 8, 2013 Dec 10, 2014 #10 20psiofevil said: Pushrod looks weaker to me due to it's geometry compared to what is in the video. I don't know of any push rod motor that turns 14,000 rpm. Click to expand... There's some that got close. Menard buick V6 in mid 90s went to 10,000. Turbo v6, just under 1000hp Toss one of those in your g-body.... 1987 White Turbo T - TE60 w/ Alky 12.1@113 on street tires
