I have a metco breather instead of my oil cap. What plug can I use to block off the hole on the side of the drivers valve cover? Is there a cmmon one used or a part # that works?
I bought a rubber plug from Ace Hardware that you would use maybe to seal off a beaker, and I cut a groove around it, and snapped it in to place. Used some black rtv around the groove before I installed it. Worked perfect
Why keep it and have two breathers next to each other? It has a breather jammed into the elbow and split it and oil spits out of the hole. I would gladly keep the oil cap if a breather properly in the elbow. Lmk if you know of one.
