Vacuum hoses
dnoel
I'm planning on replacing all the vacuum hoses on my GN what size hose and how many foot of each will I need to get? Or should I just order a kit from gbody or other vendor? Any input will be helpful, thanks!
Do a search for silicone vacuum hoses, there you will find some suggestions. High way stars is one vendor mentioned.
IIRC it's all either 3/32 or 5/32. If you need to replace any elbows, check valves, etc....same place. Most any of the supporting vendors carry this stuff. I got the specialized valves (cruise) at Highway Stars. You can also get the hard plastic line there too. Don't forget zip ties to help make sure they don't pop off.
The highway stars online is shut down for maintenance, but I'll check back in, thanks
