Vacuum Hose Diagragm
gnbrian
Does anyone know where to find the complete vacuum hose diagragm? Especially any that are engine related?
if it 86-87, here you go
the diagram should be on your a/c box under the hood
There is a vacuum line that comes from the firewall that is routed on the passenger side valve cover. Where does this hook or splice into?
from the ac box youll find two plastic lines , one is supply for the ac vent doors and goes to the check vave behind the driverside valve cover (labeled HVAC in diagram)
the other l(shorter ) line comes from the a/c controller and goes to the heater flow valve at the rear of passenger valve cover
Sizes and lengths?
Is there a source out there that has a list of what sizes and lengths would be needed to replace all of the vac hoses?
