V4R IC fitment help needed
Sleeper-6
Who has used a CAS V4R? I finally got my engine back in the car an am trying to get everything else back in place. I picked up this IC while the engine was out I have never had it in my car. While putting it in tonight I can see that it's going to take some work to get everything to line up properly. it appears the it is too far over to the passenger side and will interfere with it steering idler arm (it's just about touching it.), and sitting higher on the pass side than the driver side. I could really use a few pictures of one installed so I can see how it's supposed to sit. Thanks.
Contact Steve V
He is on the board, and worked alot on mine to make it work. Perhaps he can give you some guidance. I know that I did break the original passenger side bracket and had to get a replacement from a board member.
