I have been reading about how to wire up the older 10SI and 12SI GM alternators for our old camp tractor. There is a ton of info on the net and I ran across that most of the newer than 30 years old alternators (GM ones at least) have a "voltage sensing" lead. Basically you hook this up to a common central power distribution point, and that voltage there is what the alternator regulates it's voltage to...... like it takes the voltage drop you normally see out of the equation. Example..... car running.... you can measure 14-14.2 volts at the back of the alternator.... but on my datalogger.... hooked up to the factory ECU, it only sees 13.2 volts or something...... basically if you hook the voltage sensing wire up near the ECU, it would make the alternator keep upping it's output until the voltage at the ECU (or wherever the remote voltage sensing wire was hooked up) got to the 14 - 14.2 volts.
So riddle me this, why can't we take this wire loose from the harness where it is in our car and run it to somewhere like the fuel pump area that is always low voltage in our cars.... probably due to the long wire lengths?
If we don't want or need this higher voltage all the time, why can't we hook this to a hobbs switch that at 3 psi boost or something changes the location of the remote voltage sense by using a relay with the 87 and 87A poles on it?
Anyway... it has my wheels turning about 14volts at my FP under boost and that being 15 volts probably at my ignition..... similar to a volt booster I guess..... just DIY.
