m233roller
Banned
- Jan 25, 2002
Here I am starting multiple upgrades to my buddies 6600 mile loaded astro roof GN.
UPGRADES WILL INCLUDE THE FOLLOWING.
TE-44 turbo
PTE stock location intercooler
Up pipe and Maf pipe.
THDP with dump pipe.
60lb. injectors and Turbotweak chip.
160 stat.
RJC Power plate.
Valve covers & gaskets.
Plugs and RJC wires.
Accufab Afpr with gauge on rail.
340 pump & hot wire kit.
New A/C Delco coil pack & module.
Tin Man cold air kit.
Alky control set up.
Complete set of gauges.
Front swaybar bushings & end links.
New tires & shocks.
Rear end girdled cover.
Moser axels.
Aluminum driveshaft.
Drive shaft loop.
Trans shift kit.
Aluminum trans pan.
Trans cooler.
Torque converter. About a 2800.
Lower rear control arms.
New Pypes race pro mufflers and tail pipes.
As of now we are leaving the virgin untouched engine UNTOUCHED !!
TE-44 turbo
160 stat.
RJC Power plate.
New tires & shocks.
Moser axels.
Drive shaft loop.
Trans shift kit.
Aluminum trans pan.
Trans cooler.
