upgrade ????
airwolf
Guys I have a question or two. I'm upgrading from stock to a pt52 that I'm buying from another member. It does not have an elbow with it and he says the puck won't seal properly if I use my stock elbow. My question is would I be better off using a TH style downpipe with integrated wastegate or should I go with an external wastegate?? Which setup is less expensive?? Thanks.
Cheaper depends on what downpipe you have now. If you're still stock then upgrading to a terry d/p would be better. If you already have a 3" downpipe then an external wastegate would also require a new exhaust housing, depending on which one you get. These two pieces costs about what a Terry pipe runs so in my opinion, buy the Terry pipe.
