updated parts list
v8regalowner
pick up items in cleveland oh
87 109 block, hot tanked , freeze plugs, cam bearings and cylinders honed, stock bore, with arp main and head studs. $550
standard turbo crank $275
stock heads with box of new poston performance springs $250
will ship
bead blasted valve covers. $40
bead blasted oil pan $50
timing cover with new oil pump in box, cam sensor and oil lines still attached $60
p/s pump and bracket with hoses and resivoir still attached. $50
set stock pistons and rods $60
set stock pistons and rods with 1 bad rod $45
stock turbo(needs rebuilt) with stock housing $80
throttle body $50
flywheel $20
poston 110t cam with lifters and cam button(new) $130
cloyes double roller timing set (new) $45
.10 over main and rod bearings(seal power) $40
std. seal power moly rings $40
felpro gaskets(whole set stock) $120
stock turbo cover $25
stock crossover pipe $30
For '86 & '87 models correct? If so, put me down for it. Don't have any pics, do you? Thanks.
i would have to think they are the same for 86-7, here are pics.
OK, call it sold. How do you want to be paid? Need shipped to 78023. Thanks.
will ship
bead blasted valve covers. $40-sold
p/s pump and bracket with hoses and resivoir still attached. $50-sold
throttle body $50
flywheel $20
stock turbo cover $25-sold
ttt
Parts
Is this still available..Timing cover with new oil pump in box, cam sensor and oil lines still attached $60....If so, how much to 38358....Tim
it is still available. ill have to check on shipping. i usually send it from work because ups picks up there, but im on vacation this week. ill figure it out though.
