John at J&S
- Jun 19, 2002
Kenny D. gave me a module a few years ago to play with. He wanted to see if I could "soup it up", to get more spark energy out of it.
For reference, I hooked my scope to the module while it was running on his dyno and sketched the relationship of the cam and crank sensor, and the EST signal.
I spent a couple weeks that winter playing archaeologist, dissolving and scraping, little by little.
It still works, and I was able to draw a pretty good schematic of it.
Remember, the energy stored in the coil increases with the square of the current. Going from seven to eight amps, the energy would increase by 31%.
Increasing the spark energy by lengthening the dwell won't do any good, since the module limits the coil current to about seven amps. A Boost-A-Spark might help at high RPM, if the current limit has not been achieved. Haven't tested it, though.
The current limit can be raised only by digging into the unit, and changing the current sense resistor. This would allow for higher energy, if the voltage is increased.
Here are a couple pics of the inside of the module.
