Rowdy45466
- Sep 25, 2006
Hi,
I was flipping through a few catalogs and found the Ultrachip mentioned and I am very curious. Eight chips in one is interesting.
Any one have experience god or bad with this?
Ultrachip The ultimate solution...to chip confusion! The ULTRACHIP has it all! It's like having eight individual EPROM chips in one package. Once installed, you simply select a setting which is suitable for your driving needs. Using a miniature thumbwheel switch numbered 0 to 7, the driver can select a desired performance level instantly, even with the engine running! The switch can be mounted directly in the dash, in the glove compartment, under the ashtray, in the console, or wherever is most convenient for the driver. The switch features a unique snap-lock design. The ULTRACHIP installs into your ECM (computer) in minutes, and allows for immediate improvements in performance! Fuel delivery, turbo boost, ignition timing, ignition advance curve, and fan control are programmed into the ULTRACHIP in five progressive steps. This incremental control allows the driver to adjust performance of the engine from mild to wild! This is achieved on the fly, with instantaneous results! The ULTRACHIP also incorporates a unique anti-theft settng which disables computer control of the engine, making the car impossible to start! The car thieves' worst nightmare! Other settings on the ULTRACHIP include an economy setting, a pure stock setting and give progressive performance settings. The performance settings are arranged so that the higher the number selected, the more performance is achieved through EPROM programming modifications, instant performance available at your fingertips! The ULTRACHIP is designed specificaly for the 1984-1987 Turbo Regal, Grand Natiional and 1989 Turbo Trans-Am. Installation is simple, can be performed in less than ten minutes and there are no wires to cut. Your satisfaction is guaranteed!
Product Code: PE8499613
$195.00
http://www.postonbuick.com/eshop/10Browse.asp
$195.00
