Pat (SloGN) can give you more specifics on the cars. But basically we looked for cars with where the ignition module was mounted vertically on the front passenger side of the engine.
The orientation is vertical with the coils showing like this
(top)
| 1 4 |
| 5 2 |
| 3 6 |
[connector]
(Bottom)
There were other V6 cars with modules, but Pat told me they are fast start modules that will not work. The key is to find the ones where that have the cylinder arrangement like my above diagram. We found 4 of them at the junkyard, two for me and two for him. We nab them for $15 a piece.
As far as mounting it in my car, I already had the Casper 84/85 to 86/87 ignition mounting adapter. It pretty much fit right into that adapter without much trouble. The only issue is the 3 bolts in the bottom are longer than the 86/87 module, so it sits up on those bolts were as the old ignition module sat flush with the adapter
