210 Sport Coupe
- Nov 11, 2008
Hi Guys, need your help and advice.
Got a 200R4 and was tweaking the TV cable setting. I got the geometry corrector on the Holley carb. I had another thread going that I could not get my cable to click in WOT position no matter what I did.
I went out and sourced a 0-300 psi gage, 6' of hose and the fittings. I was set to do it with a pressure test.
Long story short, the pressure port plug WILL NOT COME OUT! I used the right boxed end wrench and it started to round it off, yup she's f***ed up.
Given that I can't use the pressure port, how can I set it at the carb end?
Pull the linkage a WOT and how tight should the cable be? Maxed out tight?
The way it is set, (I have not adjusted it since this screw up), it felt like it was starting off in second gear. The rest of the upshifts seemed o.k.
Maybe loosen it up? Pull the cable sleeve away from the firewall?
What would you guys do? Please be nice, I don't want to pull the trans
