Hi All,
Some background: I have a 86 monte carlo with a 383 making ~400HP. I have a 200R4 tranny with unknown miles (has a sticker saying it was rebuilt at one point). I installed the TransGo Performance 200-4R-HD2 shift kit when i swapped the motor and put about 2-3K miles on it. Also running 2500 or 3000 stall converter.
Noticed the 2-3 shift was sluggish so i dropped the pan
I was only running half of geometry corrector bracket I needed for the holly carb,
I had the AS6-01 but not the AS4-04K
With the new bracket installed and adjusted for full pull on cable @ WOT, I need to get to about 1/4 pull before I see an increase in pressure. Is this normal? If I adjust it so that I see the pressure increase once throttle starts to move, then I don't have enough travel at WOT.
