turbov6joe
Signal 1 J-12
- May 22, 2002
Hey just wanted to get your thoughts on this......
How often do you change your turn signal fluid?
cruzn57 said:when the blinkers slow down and they turn yellow, they need to be flushed, and new fluid installed, once serviced, they will turn white, and resume the normal speed .
DO NOT let some "super tunner" tell you other wise,
consider this my tip of the day!
Pronto said:Man, I'm totally confused. How do you reset the flasher counts? I got 20 is that ok? If you adjust the flasher counts, does it change the brake light position?
