I am installing a turbo kit on my 5.3L ext.cab Z71 truck with a Meth/Alk kit here in the next week or two. I will be installing 42lb injectors and have LS1Edit tuning (Basically can change anything I want in the PCM)
I wanna run as much boost as possible at the track so my question is. How much more boost are you guys able to run when you run a methanol kit AND race gas compared to without? Also which gas do you use and do you prefer alcohol over Meth? I am trying to figure out my settings (and other stuff I need) prior to hitting the dyno for tuning.
