Turbo drain line gasket?
josh young
Does anyone know if Kirban's sells just the gasket for the turbo drain line. I see the hose and gasket for sale but cant seem to find the gasket by itself. Thanks guys!
That's where you went wrong, should have used Bud Lite instead...:D
I keep forgetting that my car is supposed to leak oil.
I guess using a Bud Light box would have kept my ''undercar rust preventative'' in operation. :D
Do you guys know where I can find those angled fittings for the drain lines along with a hose that I can fab up?
TR Custom Parts has a fabbed up A/N braided turbo oil drain kit that looks like it would work great.
Cottons sells a reproduction of the stocker.
I tried to build one with AN fittings was a disaster 1/2 diameter is not enough.
I need a custom fitted one with the fittings angled I have a hot air setup with an intercooler. so my turbo is on the back of the engine and a hole is tapped into the back of the block for the turbo oil to drain into the valley. This would be something I must makeshift myself
