M maxcom Member Joined Jun 7, 2008 Apr 17, 2010 #1 what size bolts do i need for a stock turbo with a THDP ?
C coach Guest Apr 30, 2010 #2 Hey Tom, I believe M8x 1.25x 30 will work just fine. Let a few others confirm this, but it is what I used today on my 49. Take care Donnie
W whitehot1 Well-Known Member Joined Oct 24, 2006 May 2, 2010 #4 I have found that studs work better for fastening the down pipe to the turbo. Much less chance of breaking bolts off in the turbo if you have to remove either for some reason.
M maxcom Member Joined Jun 7, 2008 May 2, 2010 #5 I found the box with the bolts and heat shield template that came with the THDP ........another senior moment :redface: Thanks all!
M maxcom Member Joined Jun 7, 2008 May 2, 2010 #6 brian said: Tom, PM sent Brian Click to expand... back atcha Brian
