I have recently seen the WOT O2's lower. Trying to figure it out. Did a few freeway runs (40-90) and had Scanmaster recall O2 at 650-680. KR was in the range of 1.0 to 1.5.
Raised the fuel in the chip 10% across all RPMs. No change.
Raised fuel pressure from 45 to 48 (line off). No change.
Raised alky from 6 to 8. No change. (It is using the methanol).
Single nozzle alky
Eric's 5.6 chip
Old walbro fuel pump, hotwired
I don't like freeway tuning, but want to make sure the car is properly tuned for fun.
I think the next steps are:
Put a gauge line on the fuel rail to make sure the fuel pump is not falling off under boost. May be time to replace the pump anyway...
Update and run the Powerlogger (with a copilot).
Wideband O2.
Dyno runs.
24 PSI (minimum with this turbo)
Thanks.
Single nozzle alky
Eric's 5.6 chip
Wideband O2.
Dyno runs.
Thanks.
