I was looking at some calcs by John Estill
And in those calcs he shows the cooling effect of water, Methanol, Ethanol, and Isopropyl.. In those calcs he shows Methanol as having the best cooling properties BUT it looks like there is more Meth being used to do so. My quesiton then is. If I were to tune my truck on Meth, then run low one day and dump water in the tank instead am I going to have any adverse effects like drowning the motor because I am pump the same amount of water as I did Meth?
John Estill's calcs:
Water injection: 0.40 lb/min of water will vaporize, cooling the air down from 150 F to 109 F.
Methanol:
100%: 1.08 lb/min of methanol will vaporize, cooling the air from 150 F to 96 F.
50%: 0.55 lb/min of methanol/water will vaporize, cooling the air from 150 F to 107 F
Ethanol:
100%: 1.26 lb/min of ethanol will vaporize, cooling the air from 150 F to 100 F.
50%: 0.57 lb/min of ethanol/water will vaporize, cooling the air from 150 F to 108 F
Isopropyl:
70%: 0.76 lb/min of alcohol will vaporize, cooling the air from 150 F to 107 F.
91%: 1.14 lb/min of alcohol will vaporize, cooling the air from 150 F to 104 F.
100: 1.50 lb/min of alcohol will vaporize, cooling the air from 150 F to 102 F.
