screaminchicken
- May 19, 2003
My TTA isn't running that great since i bought it, before it use to be tunable to 13.2, then iwhen i got it its an entire scond slower, the best i ran was 13.9 in tucson in 50 degrees. My TL says theres no knock, IAC 111/ 44% LV8 255#, TPS 4.70 v, integrator 128 02 volts 813mV, o2Xcnt 0#, Mass air flow 226 GPS, block lean 128, MAT 95.5 Deg, ECS counts 2, spark retard 0.0 deg. Battery volts 13.5V Mixture: Rich loop closed, and only 94MPH!!! Can anyone see something wrong, this was on a thrasher 92, 19psi boost with 100 unleaded fuel, and 48psi fuel. no Malfuntions ETC. all this was taken right before i got off the gas. Any help would be great, I changed Valve springs to 100psi's, got a new o2 sensor, still no help!
Eric
Eric
