TTA -6AN trans cooling lines
BallisticV6
Im in the process of changing my trans cooling lines in my TTA to -6AN braided hose....
Does anybody know what proper -6AN type fitting will work for the stock trans cooler in the radiator of a TTA?
And will a 1/4NPT male with -6AN work on the line in and outs on the 200-4r transmission?
thanks for any suggestions..................
fittings will be needed at each end, Ive seen some cool quick disconnects like a air tool for the trans end. not sure who to check with other than the big companies like earls
ATF can attack Neoprene lines.
Not to mention where the lines get too close to things beyond their operating temp..
If you want some flex at the ends that's one thing, but for the long runs, you want steel tubing.
