Hey everyone, i havent posted in a little while this summer. I wanna get the car out soon and maybe tune it a bit but i have questions. first the setup.
Stock engine 91klicks. Cottons built 200r 4 with a 2800 red stripe converter. stock .342's with an auburn posi. Stock Turbo, Siemens 60lb Mototron injectors, Walbro Pump w/ hotwire kit, and a 100 octane programmed TT chip.
As it came from TT in first gear the car hits 25lb. boost in first gear
2nd gear and third gear at about 20lbs.
and i dont believe i've paid attention to boost in 4th, I have Caspers knock, and scanmaster. i get no knock in first under that load, is it safe to change 2nd and third and should i have more boost in those gears?? a little help, i'm new to the programming end of things. thanks in advance
