This is the mystery chip in my car. Can anyone help decode it. I’m hoping it will give me the injectors and turbo size that should have been given to burn the chip.
The "TT" stands for TurboTweak. That's a very good chip.
It's a street chip 50lb injectors for use with 92 octane. 20 degrees low gear timing/18 degrees high gear timing. 17-18lbs of boost.
The maker of that chip is a member here and goes by the name Eric Stage 1. If you PM him and give him the number on the upper right corner of the chip he will tell you everything you need to know. Or email him eric@turbotweak.com
