TSM Short Block
10 SEC BUICK
I've been collecting parts to built a bad TSM motor and have since changed my mind. Here's what I have:
109 Block hot-tank and magged
Eagle Steel crank (New)
BMS off-center rods (stock length with .927 floter pin) magged
SFI internal flywheel (new)
BMS internal dampner
20 bolt stock turbo pan
Main studs
Ft. cover w/oil+water pump
At this time I rather not seperate $1700 plus shipping. I can send pics if interested. Thanks Jon
If that is everything balanced and assembled that is a steal. I just finished building my engine so I know...
Any billet mains or girdle?
Sorry guys, These are just the pieces I have gathered in order to build a motor. Nothing is assembled. All that's needed is pistons and bottom end support (weather you chose girdle or caps) + the machine work to the block.Thanks Jon
I have a couple of parties interested in the entire package. If things don't work out I'll let you guys know. Thanks Jon
